Activity Forums Boris FX Graffiti is cutting holes in Premier interface!!!
  • Graffiti is cutting holes in Premier interface!!!
    Posted by Nick Detomaso on December 4, 2007 at 12:53 am
    I installed Graffiti 5.1 as a plug in for Premier Pro 2.0.
    When it opens over Premier, the Graffiti windows cut through the Premier interface, allowing my desktop to show through.
    Oddly enough, if I open the Graffiti Keyframer (not as a plug-in) over Premier, it behaves correctly!!!
    Any ideas as to what I am seeing and how to fix this? Using nvidia quadro 560 pro video card, latest drivers for open gl.
    nvidia has no answer.
    Nick Detomaso replied 18 years, 9 months ago 2 Members · 2 Replies
  • Peter Mcauley
    December 4, 2007 at 3:33 pm
    Hi Nick,
    Well I’m not entirely clear as to why this is happening but we’ll take a look to see if there is a setting that you might be able to change to prevent this from happening. Have you tried using Graffiti in MDI mode to see if this is more aesthetically appealing?
    Cheers,
    Peter.
  • Nick Detomaso
    December 5, 2007 at 12:09 am
    Where would I find MDI mode? Working with the two programs today, I found that if I open Graffiti in Premier and then hit the Premier radio button, I can either restore or maximize Premier and the problem goes away. Very strange…
