Activity Forums Apple Final Cut Pro Legacy Graduated N/D Filter in Post? Is there such a thing?
  • Graduated N/D Filter in Post? Is there such a thing?
    Posted by Pierre on July 23, 2006 at 4:40 am
    Does anyone know where I can find a good plugin that will realistically emulate what my footage would’ve looked like had I shot it with a neutral density grad filter?
    I’m looking for something that I can use within Final Cut Pro.
    Michael
    Blub06 replied 20 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Thaxter Clavemarlton
    July 23, 2006 at 5:12 am
    Just duplicate the same footage on two video layers, one on top of the other.
    Adjust one with the Color Corrector to make it darker.
    Crop it (use a soft edge) so only the top half (or so) is visible over the lower (unretouched) footage.
    Make adjustments until it looks “right”.
    Render.
  • Pierre
    July 23, 2006 at 5:33 am
    wow. that’s great.
    Thank you !
    I’m gonna give it a try now.
  • Steve Eisen
    July 23, 2006 at 11:29 am
    Check out 55mm Plug-ins from Digital Film Tools.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Max Frank
    July 24, 2006 at 12:43 am
    Easier/cheaper way:
    1. Place Custom Gradient on top of your clip
    found in >Effects>render>Custom Gradient
    2. Right/Ctrl click > Composite Mode > Overlay
    3. Double-click on the gradient and adjust to taste.
    Enjoy.
    Wayne
    2DP G5, 3.5GB RAM, FCP HD
  • Blub06
    July 25, 2006 at 2:35 am
    I like using the 4 point garbage matte and the 8 pint for this stuff. The advantage of this filter is that it allows for a fully customized grad. I like custom arcs with one side more then the other, the garbage mattes get you there real nice like.
    Chris
  • Pierre
    July 27, 2006 at 3:47 pm
    How do you use a garbage matte? I’m new… can you tell me more specifically? I don’t want to bring the level down on everything in the sky line if that’s what you mean.
  • Blub06
    August 5, 2006 at 10:51 pm
    I appear to have screwed up, that
