Activity Forums VEGAS Pro Graduated Filter effect
  • Graduated Filter effect
    Posted by Thomas Roberts on January 18, 2008 at 2:01 am
    How can you create a “graduated filter” effect on only one shot on the timeline? I want to add some blue color to the skyline in a shot, but NOT effect the entire timeline.
    I am messing around with the Sony Color Gradient. Am I warm?
    T
    Jerry Norman replied 18 years, 7 months ago 3 Members · 2 Replies
  • Mike Kujbida
    January 18, 2008 at 1:27 pm
    You’re very very warm 🙂
    Try this as an experiment.
    Drop the “Linear Black to Transparent” grad on the timeline over top of a picture or video clip.
    Click the 2 circle and change the “Aspect Ratio Angle” to 90.
    Adjust the “Distance” as desired (0.0 for a start).
    Click the 1 circle and adjust the colour as desired.
    When you get it the way you want, save it as a preset.
  • Jerry Norman
    January 18, 2008 at 5:58 pm
    T, here is what I do:
    Track 1 (this will be your graduated filter):
    – using insert generated media, create a black to white gradient image
    – set composite mode set to Multiply (Mask)
    – add a Sony Mask Generator Effect
    Track 2:
    – insert your footage
    – make this a child of track 1
    Track 3:
    – using insert generated media, create a blue image for your new sky color.
    – keep this as a parent track
    Now, track 1 is your “graduated filter”. You can adjust the gradient to your liking. The blue (track 3) will show wherever the track 1 mask is black, and your clip (track 2) will show wherever the track 1 mask is white.
    Jerry
