Activity Forums Adobe Photoshop Gradually bluring the text + static/glitch tv changing effect
  • Gradually bluring the text + static/glitch tv changing effect
    Posted by Clyde Finn on September 17, 2014 at 8:47 pm
    I want to achieve an effect similar to this example I’ve attached. I’d like to make the text start off clear and gradually blur from left to right.
    In addition, I wanted to make the image seem as if the channel is about to be changed on the TV. Basically having the static “noise” from the tv being applied subtly as if the channel is being switched like old analog TVs used to do. I wanted to apply the static to the right side of the image where the blurring is happening. Is there any way to go about achieving this?
    I’d greatly appreciate any input. Thanks!
    Keith Carmichael replied 12 years ago 2 Members · 1 Reply
  • Keith Carmichael
    September 20, 2014 at 5:41 pm
    That looks like a radial blur: Filter > Blur > Radial Blur (choose “Zoom” as the method.)
    For the static, think about whether you want there to be white static on the negative space, or just black static on the letters.
    I’d go for just static on the letters, in which case I’d use a layer mask on the text layer. You can use noise to generate noise on the layer, and adjust the contrast up and down to get the effect you want.
