Activity › Forums › Adobe Premiere Pro › Gradual audio speed increase/decrease
  • Gradual audio speed increase/decrease
    Posted by Martin Braben on October 27, 2007 at 5:53 am
    I’ve just started using Premier CS3 and though it was very hard going at first, I’m gradually getting to grips with it. I do have one problem that at first I thought would be easy to overcome, however it’s proving to be a bit of a hair puller. I did a quick search of these forums but couldn’t see any mention of it.
    I have a small 3 minute clip, accompanied by some music. There’s no speech. What I want to know is if it is possible for me to vary the speed of the audio track. I don’t just mean select a portion of the audio clip and say increase the speed by 10% or whatever; that’s simple enough to do I know. What I want to do is say at the 30 second mark, start gradually increasing the audio speed so that maybe 30 seconds later the speed has increased by 40% I’d also like to do the reverse i.e. slow down the speed gradually as well.
    I want the audio speed to be independent of the video clip, so of course I have unlinked them.
    Is this possible in Premier?
    Vincent Rosati replied 18 years, 10 months ago 2 Members · 1 Reply
  • Vincent Rosati
    November 6, 2007 at 2:05 pm
    The only way I know how to do this is to clip your track and set the speed for each clip. This would, of course result in a sort of stepped ramp, but it might be acceptable.
    You can do more dynamic stretching in After Effects or Audition.
