Activity › Forums › DaVinci Resolve › Grading with 2K vs 4K DPX
  • Grading with 2K vs 4K DPX
    Posted by Robert Cauble on August 17, 2012 at 12:04 am
    I am planning on grading a feature film (shot with RED at 4K) in Resolve using 10 bit DPXs (RedLogFilm, Redcolor 3) and would like to know if there would be a discernible difference between grading using a 4K resolution or 2K resolution if the final output is 2K?
    VFX will get 4K files for compositing, cropping, and stabilizing. The advantages are clear there.
    Any advice?
    Juan Salvo replied 14 years, 1 month ago 2 Members · 2 Replies
  • Juan Salvo
    August 17, 2012 at 2:15 am
    Unless you really need the resolution, you’re going to be much happier with 2k. 4k isn’t twice the data, it’s four times the data, four times the processing, four times the hassle. So unless you really need it, save yourself a headache. One thing you might be better off doing though is using the r3d. Adjusting the camera metadata can often help you save so something that might have been lost.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Juan Salvo
    August 17, 2012 at 2:56 am
    off topic would an unrelated question about Resolve. This is in the wrong forum.
    I don’t know anything about lightwave unfortunately. I would post in the lightwave forum if I were you. That is if you were addressing your question to me and not Robert Cauble.
    BTW, link to lightwave forum.
    https://forums.creativecow.net/lightwave
