Activity Forums DaVinci Resolve Grading Premiere Pro CS5.5 multicam sequence?
  • Grading Premiere Pro CS5.5 multicam sequence?
    Posted by Philippe Kiener on October 23, 2011 at 5:16 pm
    Hello
    is there a way to grade a sequence that contains multicam sequences done in Premiere Pro CS 5.5?
    I can’t find an easy way to do it. XML export doesn’t work for that kind of sequence. Right now, I’m exporting my sequence as a quicktime movie and I let Resolve find the different cut, but there should be an easier way to do that.
    Do you guys have any ideas on how to do that?
    Greetings,
    Philippe
    David Biederbeck replied 14 years, 5 months ago 2 Members · 3 Replies
  • David Biederbeck
    April 13, 2012 at 7:07 pm
    Did you ever find an answer/solution for this?
  • Philippe Kiener
    April 13, 2012 at 7:29 pm
    No.
    What I do now, is that I don’t use the multi cam sequence or:
    I edit in multicam, export as Prores, then I put my exported sequence just above the multi cam sequence, I cut it the same way as my multi cam sequence and then I do a new timeline and put my cut sequence on it and export it as Final Cut XML.
    There should be a better way to do that…
    If you have any ideas…
  • David Biederbeck
    April 13, 2012 at 7:33 pm
    I don’t know. I’ve just downloaded Davinci lite to try and move to premiere. I may just resolve to stick with FC7 and Color until I can find a substitute.
