Activity Forums Apple Final Cut Pro Legacy Grading flare when text fades out
  • Grading flare when text fades out
    Posted by Sam Bailey on April 11, 2011 at 2:49 pm
    Hello helpful people!
    I’m having a little problem that I have found a way around, but wanted to see if anyone else had any problems like this, and what it could be.
    After running a Quicktime self contained bounce off of FCP, I’ve been using QT7 to export the film to 720p good quality etc. to send to a client – am running off lots and lots since there are lots of changes being made. In one clip as a graphic fades out, the image suddenly pops and gets noticeably brighter, it then pops back a frame or two before the end. It only happens on this one clip.
    Really strange.
    Using compressor solves the issue, but I can’t get a good enough quality at around 60mb to mail out from there, hence using QT ( I know its not the best method…)
    Anyone had the same problem and know why?
    Cheers!
    sam
    Andy Horvath replied 14 years, 2 months ago 2 Members · 1 Reply
  • Andy Horvath
    June 24, 2012 at 6:08 pm
    I have been dealing with the exact same issue. What I found that works is clicking the actual fade, then in the viewer window, drop the soft fader to about 7. When I did this, the flare went away, however now it appears that the text fades a few frames sooner than the other text. It’s still a hassle, but I would much rather deal with a quick fade than that flare issue. Hope this helps!
    Cheers.
