Activity Forums DaVinci Resolve Grading does not appear the same on two different sequences
  • Grading does not appear the same on two different sequences
    Posted by Jean Tertrain on April 14, 2025 at 8:33 pm
    hello again,
    please excuse me for the double posting, as this question is not related to the previous one, i hope i don’t do something unappreciated
    here, the same “grading” does not appear the same on the same shot, but on another sequence, who have the same characteristics
    i would like to obtain the same grading but not matter what i do, it is slightly bleached like that
    sorry for the noob question again
    thank you if you read me!
    kindly yours
    jean
    Jean Tertrain replied 1 year, 5 months ago 2 Members · 4 Replies
  • Michael Gissing
    April 15, 2025 at 3:48 am
    Same shot and the same grading looking different means your timeline color management is not the same. Also we have the age old problem of what you are looking at and where. If you look at a rendered file on a computer the player and the codec can affect how it looks. It seems like you might be needed to work out how to actually compare the two without the numerous variables of codec render and playback. If they are all identical and the project and timeline settings are identical then there may be a group or timeline correction happening in one project that you need to match in the other project.
  • Jean Tertrain
    April 15, 2025 at 4:04 pm
    Thank you Michael. Effectively, the colorspace of the timeline had a slight difference.
    One output color space was on Rec.709 A et the other one on Rec.709 (Scene).
    So I put them both on Rec.709 (Scene) but the problem remains.
    I am looking at the file within DV on the same monitor, but on two different sequence and the grading still does not appear the same. Could vertical resolution (one is a 2160×3840) affect the color ?
  • Michael Gissing
    April 16, 2025 at 4:40 am
    The aspect shouldn’t make any difference. Are the two timelines in the same project? If not check that the project settings are same. Check the project settings by clicking on the gear wheel bottom right. If that all matches up, then on the color page, check that you do not have the clip as part of a group clip which might have further adjustment or that there isn’t an adjustment done to the timeline.
    Finally check there isn’t an adjustment layer with a grade above either clip.
  • Jean Tertrain
    April 16, 2025 at 11:51 am
    thank you Michael for your dear presence and rigourous feedback each and every time, it is a blessing such quality help for nothing
    so you are right, again, but restarting DV et my computer did it this time…
    thank you again !
    please have a bright day
    jean
