Activity Forums DaVinci Resolve grading a DV 4/3 project in davinci resolve.
  • grading a DV 4/3 project in davinci resolve.
    Posted by Thibault Carterot on April 15, 2011 at 12:30 am
    I have trouble in getting something right in a DV 4/3 project. The aspect ratio is not quite right
    and the picture seems blurry. Is there a way to configure DaVinci to work without big loose on this type of material ?
    Best regards,
    Tribletrib
    Config : Mac Pro 2010, 12×2,4Ghz, 32Go Ram, 3xFX4000,GT120, Decklink 3D+, RED Rocket, system on Crucial SSD 250, RAID FC 8gb Lacie 24To, CYCLONE PCI expander, Resolve 7.1
    Andi Winter replied 15 years, 5 months ago 3 Members · 4 Replies
  • Margus Voll
    April 15, 2011 at 7:08 am
    HI.
    Is the picture blurry on prev. window or on external output ?
    What is your timeline settings ?
    Also if you try to look SD picture on huge hd panel that gives you the softness when picture is scaled a lot.
    Margus
    https://iconstudios.eu
  • Andi Winter
    April 15, 2011 at 11:10 am
    in the case it is interlaced,
    you got to enable both fields in the settings ->
    else the picture might seem blurry because you are using half of the resolution.
    that’s at least what i think.
  • Thibault Carterot
    April 15, 2011 at 11:43 am
    Yes, that what I did,
    but I think I have an other issue to solve : my pixel aspect ratio is not square but ‘DV’ which I think is 5/4.Do you think I can change that somewhere.
    And when I output in PAL the image is a bit distorted in comparison with the original DV footage
  • Andi Winter
    April 15, 2011 at 12:56 pm
    cant you change the aspect ration at the timeline format?
    the options should be:
    square pixel
    16:9 anamorphic
    4:3 standard def
    cinemascope
    and:
    have you tried the input scaling options at the same config screen?
    (project settings)
