Activity Forums Zaxwerks Gradientwerks crashes
  • Gradientwerks crashes
    Posted by Sean Cusson on December 27, 2007 at 1:40 am
    I just purchased Gradientwerks and have had nothing but crashes. The comp is full HD 1920×1080. Mac Intel 4 core 8GB RAM. Things are fine on a fresh boot but AE eventually crashes stating Gradientwerks as the culprit. The second error is an AE OpenGl message. I’ve tried restarting AE with Cap Locks on, turning OpenGl off and then going to the layer that has the effect applied to it. The moment I touch the layer, AE crashes again. Has anyone run into this problem? Nothing’s worse than buying a plugin and then not being able to use it. I can only assume that there’s some sort of conflict in my setup somewhere that’s causing this.
    I though the conflict might be due to the fact that I’m running Nucleo Pro 2 (maybe a memory fight?) so I disabled it but still no luck.
    Sean Cusson
    Zax Dow replied 18 years, 8 months ago 2 Members · 1 Reply
  • Zax Dow
    December 28, 2007 at 5:25 am
    Hi Sean,
    Please send me your project file. I’ll try it out here and see if it causes me trouble too.
    Best,
    Zax
    zax@zaxwerks.com
