Activity › Forums › Adobe Photoshop › Gradient tool
  • Tim Kurkoski
    August 3, 2006 at 6:47 pm
    Shape layers are special layers, you can’t paint or draw directly on them.
    What you can do is add a Gradient Overlay layer style.
    Another option, slightly more cumbersome but possibly useful in some situations, is to create the gradient on a new layer above the shape layer, then set the shape layer as a clipping mask: hold down the Alt/Option key while clicking on the line dividing the layers. (Something to note that I found while testing this- layer styles will be applied AFTER the clipping mask is done, so make sure you have any overlay styles turned off to see the results.)
