Activity Forums Adobe After Effects Gradient ramp with moving text
  • Gradient ramp with moving text
    Posted by Chris Oakley on August 8, 2011 at 11:55 am
    First post here suprisingly, so Hi.
    This is something that has always bugged me but now it has become a real pain. I am trying to apply a ramp effect to animated text (just transformations), but when the text moves the ramp does not follow it; the text just acts like a matte over a static background.
    Is there a way to set the ramp start/end points relative to the layer rather than an absolute position? (I suck with expressions) I know you could get around it by creating a solid with the ramp effect applied, add a matte for the text and parent that to the text layer, but that’s more effort.
    Any suggestions appreciated, thanks!
    Chris Oakley – Digital Media Technician & Visual Effects Compositor
    http://www.chrisoakley.net
    @chrisoakleyfx
    Charlie Davies replied 14 years, 2 months ago 4 Members · 4 Replies
  • Steve Tharp
    August 8, 2011 at 2:56 pm
    Chris,
    Dave’s technique is spot on. Another way to do it would be to pre-comp the text and apply the ramp to the text layer inside that pre-comp.
    Steve
    Steve Tharp
    Art Director
    Point7West
    https://point7west.com
  • Roland R. kahlenberg
    August 8, 2011 at 5:07 pm
    But it won’t work if the text characters are animated using Text Animator Properties. This is a shortcoming of AE having to continuously rasterize text as a default.
    Expressions may be the only solution in such cases but I’m certain that even Expressions will have its shortcomings in such cases.
    The best solution is for AE to use Text Animator groups as an effect instead of being locked down with a text layer. As an effect, one could apply a texture or gradient onto a text layer and then followup with a Text Animator effect and achieve exactly what you want.
    HTH
    RoRK
    Intensive AE & Mocha Training in Asia.
  • Chris Oakley
    August 12, 2011 at 8:14 am
    OK thanks for the advice guys.
    @chrisoakleyfx
  • Charlie Davies
    June 20, 2012 at 8:56 am
    An easier way to get it to move and stay with the text is to apply a Gradient Overlay in the layer styles, directly in the text layer
