Activity › Forums › Adobe Photoshop › Gradient question
Gradient question
Posted by Bob O dell on August 9, 2005 at 4:25 amCan you put more than one Gradient in an ellipse or other Vector shape?
I need Gradients like in fireworks Ripple, Waves…
Thanks for any help
Richard Harrington replied 21 years, 1 month ago 3 Members · 2 Replies -
Kim Mackenzie
August 9, 2005 at 11:13 amMore than one gradient per layer, no, but you can put additional gradients on layers above, then change the blending modes on those layers so they’ll modify the layers below.
If you group the layers (in the layers palette, option or alt click between the layers), then the layers above will be masked by the bottom layer.
Richard Harrington
August 10, 2005 at 2:01 amYou can add a gradient fil layer and paly with the scale command
or you can edit the gradient with the gradient editor and just repeat ABABABAB
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.comedit – produce – direct –
