Activity Forums Adobe After Effects Expressions gradient on text that’s deformed on a path
  • gradient on text that’s deformed on a path
    Posted by Matt Howarth on December 7, 2021 at 5:06 pm
    Hi all
    I want to create some text that has a colour gradient going smoothly from the first letter to the last and the text is deforming along a path. If I add a grad as a layer style or as an effect, the text deforms through the gradient rather than the grad being “stuck” to the text. Any thoughts?
    thanks
    Matt
    Matt Howarth replied 4 years, 9 months ago 2 Members · 2 Replies
  • Matthew Woods
    December 7, 2021 at 9:46 pm
    Try this: Make your text one color. Apply a “Stroke” effect to the text layer and set its path to the same path as your text. Make the stroke your second color, set its paint style to “On Original Image” . Adjust the brush hardness to get your gradient correct. Last apply the “CC Composite” effect with Composite Original set to “Stencil Alpha.
    Cheers,
    Another Matt
  • Matt Howarth
    December 7, 2021 at 10:44 pm
    Hi Matt,
    Thanks, that’s a really interesting technique, I’ll give that a whizz tomorrow.
    Thanks again
    Matt
