Activity › Forums › Adobe Illustrator › Gradient on stroke showing weird results
  • Gradient on stroke showing weird results
    Posted by Otto Lindqvist on September 26, 2012 at 6:13 am
    Hello,
    First time I’m posting on Illustrator section..
    To the problem. I crashed into a problem when using gradient on a stroke. I have this curved path where is a stroke coloured with gradient going on the path. All the curves are on same angle (created with guides) but the middle curve have these weird bumps on it. I wasnt able to find out why that is happening. Have you ever seen anything like that? And how to solve it?
    If it’s not moving, animate it
    Vincent Rosati replied 13 years, 12 months ago 2 Members · 1 Reply
  • Vincent Rosati
    October 8, 2012 at 11:47 pm
    Not exactly sure what’s happening here, but I’d try using the Convert Anchor Point Tool on that point – under the pen tools.
    Click-and-Drag the point.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
