Activity Forums Adobe Photoshop Gradient on a stroke
  • Gradient on a stroke
    Posted by Stephan Dube on May 20, 2008 at 3:23 pm
    Im trying to put a gradient on a stroke however I am unable to do this. the work around thatI found is to do a rectangle and put a gradient inside of it and use the Warp tool to make half of a circle however the circle is not a perfect half of cricle even if I put 50 “make with mesh” value. anyone has any other suggestions?
    thanks
    Stephan Dube replied 18 years, 4 months ago 1 Member · 1 Reply
  • Stephan Dube
    May 20, 2008 at 6:11 pm
    Just in case Im not clear on my goal here is to create an arc with a gradient inside of it. However when I use the “Make with Warp” tool my half circle isn’t perfect and I need it to be absolutly perfect. Inside of my half circle id like to have a gradient inside of it. thanks
