Gradient help – should be simple?
I’m having a hard time figuring this out, so if anyone could help I’d much appreciate it.
Anyway I would like to make a rectangle, like a frame around the outside of the… frame. So maybe a 40-pixel wide rectangle that goes the entire way around my DV widescreen frame. I’d like it to be a gradient from black at the outside edge to a dark grey at the inside edge of the frame (all the way around), but I can’t figure out how to make this happen.
In photoshop, I can do 4 straight lines, but the corners are messy. There’s also a circle gradient, but no rectangle.
In AE, there’s ramp – which again will do a circle or a line, and there’s 4-color gradient which comes closer but still not perfect.
The closest I came was to make a blac rectangle, then a grey one slightly larger, blur they grey one and delete it to create the gradient frame. Close again but not quite what I want.
I do not need/want the opacity to gradate, just the solid color – again from black on the outside of my rectangle, to grey on the inside. Is this at all possible?
Thanks.
Scott Bush
