Activity Forums Adobe After Effects Expressions Gradient controlled time remapping? (Rolling shutter effect)
  • Gradient controlled time remapping? (Rolling shutter effect)
    Posted by Mathias Kalhauge on September 17, 2018 at 8:22 am
    Hey, so I’m trying to make a, sort of, rolling shutter effect to a layer in After Effects, but I don’t know how to go about this.
    My only guess is that I need to make an expression in time remapping, which looks at a gradient to determine how much delay is needed – using Dan Ebberts’ method:
    x = thisComp.layer(“Gradient”).sampleImage(transform.position, [.5,.5]/2, true, time)[0];
    100*[x,x]
    The only problem is that it will affect the entire image, instead of affecting it in segments, just like rolling shutter does.
    Does anyone know how to do this properly?
    Mathias Kalhauge replied 8 years ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    September 17, 2018 at 4:10 pm
    “Gradient-controlled time remapping” describes the time displacement effect.
    https://helpx.adobe.com/after-effects/using/time-effects.html#time_displacement_effect
    Considering it will look at the full frames that actually exist in the footage rather than trying to recreate in-between motion, it will not exactly be rolling shutter effect. The time displacement needs to be several frames to create a proper result, so it is more of a slit-scan effect.
    Rolling shutter would be motion that occurs in less than one frame. You could conceivably achieve a rolling shutter type effect if you generated additional footage between frames with pixel blend.
    Senior Graphic Designer
  • Mathias Kalhauge
    September 18, 2018 at 1:00 pm
    Thanks man!
    Time Displacement works great
