Activity Forums Adobe After Effects Gradient control similar to Photoshop
  • Gradient control similar to Photoshop
    Posted by Jonathan Alexander on February 7, 2006 at 12:02 am
    Is there a way to make a custom, vector gradient effect in After effects, where I can have multiple colors, not just the 2 that the “ramp” effect comes with? It’s nice adding the gradient overlay style in photoshop, is there a similar way in After effects? I feel there should be. I know that I could just create something like that in Phosohop, but then once I bring it into AE, it will be rasterized and I want to be able to take advantage of a vector gradient that I can scale up and zoom in on without destroying the quality. There has to be a way native to AE in which this can be done, please tell me how!! Thanks!
    –Jonathan
    Roland R. kahlenberg replied 20 years, 7 months ago 6 Members · 7 Replies
  • 7 Replies
  • John Dickinson
    February 7, 2006 at 12:11 am
    There are two third party plug-ins I know of:
    Zaxwerks: The Works Vol 1
    Digital Anarchy: Gradient!
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Jonathan Alexander
    February 7, 2006 at 12:17 am
    Hmmm…thanks for those, I will check them out. Seems to me, that more gradient control should be something native to After Effects, maybe I’ll reccommend it, but I would be surprised if I were the first to do so. Thanks for the plugins though, I appreciate it.
    –Jonathan
  • Pierre Jasmin
    February 7, 2006 at 3:24 am
    FYI, another technique is RE:Fill from us (revisionfx.com) which allows you to put color dots anywhere and make a full color frame from that
    Pierre
  • Roland R. kahlenberg
    February 7, 2006 at 4:21 am
    4-color Gradient does a decent job. If you set the vertical settings for each colour position to be identical then you can get something rather useable. Re:VisionFxs Re:Fill does a lot of other things too besides gradients. So that’s a good plugin to look at.
    HTH
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Austin Wallender
    February 7, 2006 at 6:52 am
    What I usually do is create a standard black to white grad with Ramp, and then apply Colorama. That lets you add lots of color points, and change the transitions from color to color and even the transparancy of each point…. very handy, and no 3rd party neccesary.
    -a
  • Steve Roberts
    February 7, 2006 at 11:14 am
    Very handy indeed, Austin. I had forgotten that one.
    February 7, 2006 at 12:12 pm
    Hi Austin
    That’s another good option that you pointed out. Thanks for contributing to the COW.
    Cheers
    RoRK
    broadcastGEMs
    customizable backdrops with Adobe After Effects project files
