Activity Forums Blackmagic Design Gradient banding with Blackmagic 10bit codec
  • Gradient banding with Blackmagic 10bit codec
    Posted by Elena Ho on September 20, 2007 at 5:25 am
    I understand that rendering with the Blackmagic 10bit with Trillons of Colors removes gradient banding in renders.
    I’ve recently worked on a project in After Effects 6.5 my project was setup to 16bit and rendered my composition with the Blackmagic 10bit with the Trillons of Colors codec and there were obvious significant banding issues. I rendered the same composition again with the Lossless (Millions of colors) codec and there was no banding to be seen.
    I’m running on 4 x 2.5 GHz PowerPC G5 (5.5 GB DDR2 SDRAM)
    I currently have Blackmagic Decklink 6.3 installed.
    So my question is, am I missing a step in the project/ render setup? Why is it that I still have banding issues with the Blackmagic 10 bit (TOC) codec?
    Chris Borjis replied 19 years ago 2 Members · 1 Reply
  • Chris Borjis
    September 21, 2007 at 3:31 pm
    What are you monitoring this on?
