Activity › Forums › Apple Final Cut Pro Legacy › Gradient Banding
Gradient Banding
Posted by John Orchard on May 18, 2010 at 5:19 pmHey guys!
Anyone have a workaround for bad gradient banding? My only solution has been to export in ProRes, but the files are just too large.
John
Michal Trzaska replied 13 years, 8 months ago 6 Members · 5 Replies -
Stephen Smith
May 18, 2010 at 5:29 pmHow About: Effects, Video Filters, Image Control, Reduce Banding. Best of luck.
Check out my Motion Tutorials
Jerry Hofmann
May 18, 2010 at 5:31 pmBanding is more prevalent in 8 bit video. ProRes is 10 bit so that’s why it looks better… still has a bit, but it’s much better than 8 bit.
There isn’t a real work around for this, other than what was suggested. If that isn’t good enough, might try blurring the gradient a bit, but it won’t look as good as the ProRes version would.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
John Pale
May 18, 2010 at 8:39 pmNote also that your display card and monitor can introduce banding not in the actual file if they are not capable of displaying 10 bit info.
Sven Giebel
May 18, 2010 at 11:42 pmBlurring the gradient won’t help I’m afraid, it will make things worse. Try adding a bit of grain, sometimes this helps.
good luck -
Michal Trzaska
December 6, 2012 at 3:53 pmGradient Bending is vary annoying, I found it that if you make your gradient in Photoshop and add the noise filter it helps a lot.
If you are in Final cut you will need to do some more work.
To your gradient layer apply a “Add Noise” filter.
You will need to mess around with the settings here a bit.
-Bring down the Amount, I have it at 1.4
-Type: White noise (Uniform) works fine
-Blend mode, I used Overlay
-Autoanimate, Unchecked, we want eh noise not to move
-Mix, if you want even less noise bring down the “opacity” here.It’s a fine line you want the eliminate the bending of the colors but you want the image to stay crisp.
Hope this helps,
MeHowMichal Trzaska
Editor, Colorist, Director of Photography, VFX Artist and Motion Graphics Artist
MeHow Design
TV Commercials for your Google TV ads. Web Videos that get results
