Activity Forums Adobe Photoshop Gradiant Transparent Effect on Graphic
  • Gradiant Transparent Effect on Graphic
    Posted by Ryan Osika on May 27, 2005 at 5:46 am
    This seems like something that should be easy, but I can’t for the life of me figure out how to do it. I have a solid graphic that I want to make into a “lower third” for a TV show. It needs to gradually become transparent from the left to the right side of the screen. How can I do this? Please help. Thanks very much.
    Ryan
    Jeff Cochran replied 21 years, 4 months ago 2 Members · 1 Reply
  • Jeff Cochran
    May 27, 2005 at 6:02 pm
    Create a gradient on an alpha channel
    Go to the window pull down menu > Channels and create a new channel
    Create a gradient from white to black. The white will be opaque. the black transparent.
    However you save the file, make sure you save with alpha channels. If your saving as a Targa, save with 32 bit.
    Good Luck
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
