Activity Forums Avid Media Composer Graded transparency
  • Graded transparency
    Posted by Matthew Kelly on February 24, 2008 at 3:56 pm
    Is it possible to grade the transparency of a clip i.e. the left side of the clip is solid and the image gradually reaches 100% transparent at the right side of the clip??
    (I’m on AVID Media Composer/Adrelaline)
    Jon Zanone replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jon Zanone
    February 25, 2008 at 4:26 am
    Have you tried the title tool?
    Create a box the size of your frame and play with the transparency. You can control the gradient by adjusting the size of the box.
    You’ll get more control of the gradient by using Photoshop, though. Export a frame of video, import into PShop. Create a transparency and save as a .png.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
