Activity › Forums › DaVinci Resolve › Graded at improper frame size, can I copy over grades?
  • Graded at improper frame size, can I copy over grades?
    Posted by David Powell on April 15, 2012 at 12:01 am
    So I rendered a 720p movie to prores HQ that went to 1920×1080, didn’t realize I had done this t’ill after I finished grading and rendered out the final movie. This was a flat movie grade. I’m wondering is there a way I can bring in the proper size movie and copy the grades shot by shot? Or export a grade edl or sorts and bring it on top of the proper movie?
    Ola Haldor voll replied 14 years, 5 months ago 4 Members · 6 Replies
  • Ola Haldor voll
    April 15, 2012 at 12:51 am
    Do I understand you correct?
    – You received a single QT file
    – Scene Cut or EDL to split at edit points
    In theory, you should be able to just replace the file. Give the old one a new name and give the new 1080p file the old file name of the 720p file.
    Resolve won’t know what happened. Go to Config set 1920×1080 as the resolution.
  • David Powell
    April 15, 2012 at 1:27 am
    excellent, so I can put the highres file in under the first files name, open the project and re-render at 1920×1080. I’m hoping that will work. Thanks a bunch.
  • Arthur Dobbe
    April 15, 2012 at 9:27 am
    Yes, using the ColorTrace function you can copy the grades shot by shot. See manual for ‘ColorTrace’.
  • Ola Haldor voll
    April 15, 2012 at 9:39 am
    In THEORY, it should work, as long as the edit is exactly the same and the filename is the same.
  • Eric Johnson
    April 15, 2012 at 8:59 pm
    The only big issue could be any shapes…. Aren’t those based on the timeline size that they were created in?
  • Ola Haldor voll
    April 15, 2012 at 9:44 pm
    If he resizes the timeline from 720p to 1080p, it wouldn’t be a problem as far as I know. Shapes should resize accordingly.
