Activity Forums VEGAS Pro Grabbing the Fade in offset gizmo
  • Grabbing the Fade in offset gizmo
    Posted by Greg Fitzpatrick on March 25, 2015 at 7:41 pm
    Does anybody have a suggestion for how to easily grab the Fade in offset gizmo? Eventually I latch on to it but often it is a hit and miss affair between Fade in offset and Trim event start. Must be a method…
    John Rofrano replied 11 years, 5 months ago 2 Members · 1 Reply
  • John Rofrano
    March 26, 2015 at 12:13 pm
    The Fade is only available in the upper corner. If you are grabbing the trim event then you are clicking too low. Just click in the upper corner. I have no issues with this at all. Also try zooming n a bit. The more you zoom into an event the easier it is to see the fade handle.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
