Activity Forums Apple Final Cut Pro Legacy Grabbing stills…any easy method?
  • Grabbing stills…any easy method?
    Posted by Adam Taylor on February 7, 2008 at 11:22 am
    I need to grab lots of still frames from throughout a rushes tape. Its all digitized into FCP and i had forgotten what a pain grabbing stills actually is….
    does anyone know of a quick and easy (preferably 1 or 2 keystrokes) that will allow me to rapidly progress through the material and grab a single frame whenever i see a suitable one?
    The method i use currently is to mark in/out, export quicktime conversion, select still image, enter…all of which needs to be done with mouse/pen….and its taking forever!!!
    please help !
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
    Raafi Rivero replied 16 years, 1 month ago 6 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    February 7, 2008 at 11:48 am
    [lightning ad] “The method i use currently is to mark in/out, export quicktime conversion, select still image, enter…all of which needs to be done with mouse/pen….and its taking forever!!!”
    You don’t need to mark any in or out for stills. FCP always exports the still where the playhead is parked.
    You can also use Apple’s Screen Grab utility if these stills are just for someone to view on a computer. Shift/Apple/4 they draw around the video image.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Adam Taylor
    February 7, 2008 at 12:13 pm
    thanks Walter – no i/o? well whaddaya know!
    The apple screen grab is no use for this job – not enough screen real estate to grab in the resolution i need.
    ps. your color dvd finally arrived yesterday, Walter. Very useful….now if only i can convince the powers that be to get me a Tangent panel or an Eclipse !!!
    adam
    Editor/Mixer
    Oldham, UK
  • Walter Biscardi
    February 7, 2008 at 12:17 pm
    [lightning ad] “ow if only i can convince the powers that be to get me a Tangent panel or an Eclipse !!!”
    completely unnecessary in my work. I have found better uses for $5,000 – $20,000 in my shop. 🙂
    Read my Blog!
  • Steven Gonzales
    February 7, 2008 at 1:28 pm
    Quicktime Pro has export options in its dictionary for Applescript. Here’s an example of a script that exports from Quicktime Pro.
    Perhaps you could easily modify to export still of the current frame, then do this export work using Quicktime Pro
    https://bbs.applescript.net/viewtopic.php?id=15111
  • Zak Mussig
    February 7, 2008 at 3:29 pm
    Hey Adam,
    When I’ve had to export lots of stills I make a bin, make freeze frames (Shift-N) and drag them into the bin. Then I batch export as whatever file type I need and use Automator to rename them. The only slow-ish part is dragging the freeze frame.
    Hope that helps,
    Zak
  • Adam Taylor
    February 7, 2008 at 3:33 pm
    thanks guys…
    steven – i couldn’t open the link – says server not responding!…but then i don’t have the time to learn scripting at the moment>
    zak – great idea…i’ll remember that for next time. I just finished the job two minutes before your post popped up!!
    regards
    Adam
    Editor/Mixer
    Oldham, UK
  • Alan Lacey
    February 7, 2008 at 5:03 pm
    Zak, that’s the method I’ve been using recently. I’m not a MacHead though, could you please outline the ‘automator’ steps for renaming?
    Thanks a lot
    Alan
  • Raafi Rivero
    August 8, 2010 at 10:42 pm
    I know it’s, like, two years after this thread got started, but this problem has always plagued me and it’s the first hit on google… AND I’ve found a great solution via apple’s pro tips:
    https://www.apple.com/pro/tips/screenshots.html
    I generally edit with my second monitor set to preview and therefore have a full version of the screen up at all times. Now, I click Apple+Shift+4 to bring up the crosshairs, *important* then press [SPACEBAR] and the crosshairs turn into a little camera icon. Simply click on the full-screen image, and the screengrab automatically pops up on your desktop.
    Hope this helps someone else too!
    r
