Activity Forums Adobe Premiere Pro GPU Ripple effect – Unable to animate it?
  • GPU Ripple effect – Unable to animate it?
    Posted by Timo-uk on August 14, 2006 at 5:41 pm
    Hi, the 3D GPU ripple (circular) effect bundled with Premiere Pro looks great, as you can tilt it and the ripples are in true 3D. However, I can’t seem to animate the phase of it in order to try and make it ripple in motion (ie. animate the infinite “spreading out” of the rings), like water.
    Instead, it doesn’t animate at all. There doesn’t seem to be any “Phase” control on there to animate the spreading out of the ripples:-
    https://img139.imageshack.us/img139/478/gpuripplepu3.png
    The “Ripple Amount” merely changes the amplitude (height) of the waves.
    Is it not possible to animate this rippling effect?
    Are there any other plugins that have this same great 3D perspective look (ie. that you can tilt), and that do animate?
    Many thanks indeed.
    Timo
    Timo-uk replied 20 years, 1 month ago 1 Member · 1 Reply
  • Timo-uk
    August 17, 2006 at 1:12 pm
    Last bump.
