Activity Forums DaVinci Resolve GPU Ram for 4K projects, how much is enough?
  • GPU Ram for 4K projects, how much is enough?
    Posted by David Pirinelli on April 26, 2012 at 2:08 am
    I have tried to answer this question many times in the past and been unable to.
    I am an Art Director with MANY years in film biz. I am NOT however a colorist.
    And I don’t know the software well enough to test beyond “It works”
    So I discussed this with someone who knows the software better than just about anybody.
    He tried a GTX285 1GB vs a GTX285 2GB.
    I will let the expert’s words speak :
    “With the stock 1G GTX285, using a 5120×2700 Red Epic file and timeline resolution, 2 parallel blur nodes runs out of GPU RAM. With the 2G GTX285, I get up to 14 parallel blurs nodes. Adding the 15th parallel blur node runs out of GPU RAM.
    A 5120×2700 resolution timeline would be near a worse case scenario I think, at least on a Mac. Of course you would not usually grade a project at this timeline resolution, but you may well want to render it out at the native file resolution. I think 14 parallel blur nodes is plenty of headroom for most normal grading. I doubt anyone would have an issue with that. So for high resolution timelines, the 2G card would definitely be desirable over the 1G card.”
    So somewhere between 1 GB and 2 GB seems to be the current “Magic Number”.
    Gabriele Turchi replied 14 years, 4 months ago 13 Members · 30 Replies
  • 30 Replies
  • Gabriele Turchi
    April 26, 2012 at 2:34 am
    As stated many times by BMD ,
    2 x GTX580 3GB Ram are the minimum requirement to work on a 4K timeline
    You probably tried only 1 shot to get those performance (and honestly those performance seem a bit to optimistic for a GTX 285)
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX470
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
    Ultrascope
  • David Pirinelli
    April 26, 2012 at 2:37 am
    Was a BMD employee who wrote that.
  • Gabriele Turchi
    April 26, 2012 at 2:45 am
    Rohit and Peter both said that 3GB is minimum to Have a smooth session on 4K timeline (and 2 or more
    Card are suggested )
    I had problems with 3x GTX470 when I tried to render out a movie at 4K
    Resolution …
    g
    MacPro
    Cubix desktop 4
    2 Red Rockets
    24GB RAM
    HP Dreamcolor
    Ultrascope
  • Jonathon Lee
    April 26, 2012 at 5:09 am
    Here is repost of when I asked this…
    ____
    ____
    Re: GPU RAM question
    by Peter Chamberlain on Mar 5, 2012 at 5:53:28 pm
    We recommend 3GB GPU ram if you plan on doing 4K work.
    1.5MB will get you by sometimes but its not advised.
    Peter
    ____
    ____
    It took me a few tries to, but eventually it was answered by the BMD folks. I’ll be testing out one of your GTX 570’s w/2.5GB… so we shall see how that does.
    – JL
  • Margus Voll
    April 26, 2012 at 6:04 am
    It seems that 1,5 gig tends to run out of memory in some cases and 3 gigs are recommended therefore to
    have some memory overhead?
    Margus
    https://iconstudios.eu
    DaVinci 8.2.1 OSX 10.7.3
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • David Pirinelli
    April 26, 2012 at 6:15 am
    “So somewhere between 1 GB and 2 GB seems to be the current “Magic Number”.
    Looks like my guess & source at BMD were right.
    Good to know what the “Minimum” is.
  • Margus Voll
    April 26, 2012 at 6:39 am
    so we could presume 1,87 ? 🙂
    Margus
    Multibridge 2 Pro
  • James Milner-smyth
    April 26, 2012 at 12:48 pm
    We found the issue with 4K plus rendering may not just be about the cards but the OS you are on.
    Using 3xGTX470 on Mac OSX Resolve we could grade OK but it would not render a single frame at 4K: it would stall with no error reported and hang.
    Switching the project to a Windows 7 based Resolve with the same GFX cards rendered fine.
    James Milner-Smyth
    CTO The Post Factory Group, London
    Post Factory, Gear Factory, Look Factory
    https://www.postfactory.co.uk
    https://www.gearfactory.co.uk
    https://www.lookfactory.co.uk
  • Colin Travers
    April 26, 2012 at 1:41 pm
    I upgraded to Lion in order to put in a 580 standard Newegg card along with my 120 things work well now for rendering beyond 2K.
    DaVinci 8.2 OSX 10.7.3
    MacPro 12-core 5,1 2.66 Ghz
    32GB RAM x4 8GB
    Software RAID 0 (8TB Internal)
    Nvidia GT120/GTX580
    BMD Extreme3D
    HDlink3D DisplayPort
    Dreamcolor/Panny VT25
    Tangent Wave / Wacom
  • Gabriele Turchi
    April 26, 2012 at 2:33 pm
    the full res rendering thing is still a mystery to me …
    at my office i have Lion 10.3 and i have hard time to render even in HD but having R3D set at full rez (even resetting PRAM)
    at home i have Lion 10.3 and it render like charm , there must be something else involved in that issue ..
    g
    MacPro
    Cubix desktop 4
    2 Red Rockets
    24GB RAM
    HP Dreamcolor
    Ultrascope
Page 1 of 3
