Activity › Forums › Adobe Premiere Pro › GPU Quadro 4000 Premeire CS6 not working
  • GPU Quadro 4000 Premeire CS6 not working
    Posted by Robert Behnke on July 18, 2012 at 7:00 pm
    CUDA for the Adobe Premiere playback engine is not working correctly. I have to use software only for transitions, dissolves, etc. to work properly. Everything outside of Premiere seems to be fine… but maybe it is not. GPU is up-to-date and so is Lion. Quadro is running headless and the monitors are driven by the ATI card. Thanks!
    Michael Murphy replied 14 years, 2 months ago 3 Members · 5 Replies
  • Walter Soyka
    July 18, 2012 at 7:45 pm
    [Robert Behnke] “Quadro is running headless and the monitors are driven by the ATI card.”
    This could be the problem. If you drive the monitors from the NVIDIA card, presumably everything works correctly?
    Walter Soyka
  • Robert Behnke
    July 18, 2012 at 9:16 pm
    Nope. That does not work either. Thanks!
  • Walter Soyka
    July 18, 2012 at 9:30 pm
    Do you have the CUDA drivers [link] installed?
    Walter Soyka
  • Robert Behnke
    July 18, 2012 at 10:34 pm
    Yep. 4.2.10 Thanks!
    Lion 10.7.4
  • Michael Murphy
    July 18, 2012 at 11:33 pm
    Conflict between the cards?
    I have had to disable on-board cards in the BIOS in the past when installing new cards in a slot. Same can apply to two cards in slots.
    You might also check that the card is correctly enabled in the text file? though it would not show up as “Mercury Hardwate Acceleration” if not.
    You do have to re-enable hardware acceleration after an upgrade if you used the hack.
    Some reading – might help??
    https://www.studio1productions.com/Articles/PremiereCS5.htm
    Good luck!
    Best,
    Michael
