Activity Forums DaVinci Resolve GPU card problems with Resolve 8
  • GPU card problems with Resolve 8
    Posted by Jeff Brown on July 18, 2011 at 11:11 am
    Hi All
    I have a GT120 (GUI) and a FX4800 (GPU) which worked fine with v 7.12 of resolve. Having upgraded to 8 I now get the error message that the GT120 is being used for image processing and is not optimal. Both cards are installed with correct drivers and Cuda revision and show up in device manager. (I’ve tried both the recommended 3.2.17 cuda with the installer and also rolled to a newer version 4)
    Running an 8 core tower with JMR blustor expander (GUI GT120 in expander and 4800 in slot 1 of the tower).
    As a result I’m getting 8-10fps when before I was getting 23-25fps. It’s also prone to crashing out whenever I try anything heavy.
    Any suggestions?
    Cheers
    Jeff Brown
    https://www.brownianmotion.co.uk
    Jeff Brown replied 15 years, 2 months ago 3 Members · 3 Replies
  • Dan Moran
    July 18, 2011 at 1:24 pm
    Hi Jeff,
    Can you send me an email at davincihelp@blackmagic-design.com ?
    If you could include your system profile and if you can click capture logs and send them to me also.
    You can find this at
    Library/Application Support/Blackmagic Design/DaVinci Resolve
    I’m sure I’ll be able to help you out!
    Dan
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Christopher Tay
    July 18, 2011 at 1:50 pm
    Why don’t you try install the GT120 in slot 2 in the Mac Pro and connect the GUI monitor to the GT120.
    Resolve v8 may not like the two graphics card in separate locations.
    -chrispy
  • Jeff Brown
    July 18, 2011 at 5:57 pm
    All sorted – thanks for the speedy response Dan. Worth noting that you can’ have any monitors attached to your GPU cards else they are not used.
    Cheers
    Jeff
