Activity Forums Adobe Premiere Pro GPU accellerated rendering – No difference if unchecked
  • GPU accellerated rendering – No difference if unchecked
    Posted by Bogeyb on May 9, 2006 at 1:14 pm
    I am a little disappointed of PPro’s new feature “GPU accellerated rendering”. There’s absolutely no difference in rendering time whether I check or uncheck the box in the Project Settings Window.
    I tested with cross-dissolves, opacity, 3-way color corrector and fast color corrector.
    Another issue: Even if the GPU accelleration is activated there is always the red “needs to be rendered”-bar above the timeline.
    I have a Nvidia 6800 GS graphics card (newest ForceWare-Driver 84.21) on an AMD X2 4200 DualCore System with 2 GB of RAM. The NVidia Driver is set to “optimal Performance” and the PPro-Task has the highest priority.
    Has anyone an idea how to configure the System/Drivers/PPro 2 to know the true promise of GPU accellerated rendering???
    Thanks for your help,
    Sebastian
    Bogeyb replied 20 years, 4 months ago 3 Members · 3 Replies
  • Alex Udell
    May 9, 2006 at 4:59 pm
    I’m not sure, but Ithink you have to use this in concert with the specific GPU FX…
    Al-x
  • Aanarav Sareen
    May 9, 2006 at 8:01 pm
    First off…Its GPU accelerated playback and rendering I have run numerous tests to see if this works and it does. Infact, Steven ran a few tests while we were on the phone and he will give you the same answer that I did.
    [BogeyB] “Another issue: Even if the GPU accelleration is activated there is always the red “needs to be rendered”-bar above the timeline.”
    GPU accelerated playback does not mean that you do not have to render. You have to render whether the option is turned on or not.
    [BogeyB] “Has anyone an idea how to configure the System/Drivers/PPro 2 to know the true promise of GPU accellerated rendering???”
    I have the 6800GO (mobile version) and it works on my end. Can you run a few tests and provide us with test results, in terms of time taken when GPU Accelerated Playback is activated and when it’s de-activated?
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Bogeyb
    May 10, 2006 at 5:28 pm
    Thanks for your posts…
    OK, Here are some rendertimes:
    a) Two 30 second DV Clips with a 30 second cross dissolve between them: Rendering-time: 13 seconds whether checked GPU accellerated rendering or not.
    b) a one minute DV clip with the quick color corrector needs 33 seconds to render whether activated GPU rendering or not
    In both cases, rendering times are exactly the same, and – what i wonder about – in both cases rendering time is less than the original clip-lenght. So my machine is rendering “faster than realtime”, but playing back directly from the timeline the preview quality is reduced (if set to auto), or the playback is stuttering if preview quality is set to “high”.
    Any ideas, guys??
