Activity Forums VEGAS Pro GPU Acceleration Problems
  • GPU Acceleration Problems
    Posted by Mark Krueger on November 22, 2011 at 1:52 am
    Here is the scenario:
    1. Upgraded to Vegas 11 build 425 64 bit.
    2. Had a new video card installed to take advantage of Accelerated
    GPU. (Nvidia GTX570)
    3. Vegas 11 recognized the card and I set in the preferences to
    use it for processing.
    Here is the problem:
    The video displayed in the preview window on the “preview auto” setting is dark. When I change it to “FULL Best” it is blown out and very grainy.
    When I change the settings back to not using the GPU acceleration, the preview is good at both settings.
    Obviously, I thought using the GPU accelertion was suppose to improve picture quality and performance, but it is having a negative affect.
    Any ideas here? Does the Dynamic RAM Preview settings have any affect here. It is set a 200 with a max range listed as 7159MB
    Scott Francis replied 14 years, 10 months ago 3 Members · 2 Replies
  • Shailesh Pranjivan
    November 22, 2011 at 3:23 am
    I am also have the same problem. Only that the playback is very choppy. I have a geforce gt 520. I have updated my driver and also the beta driver to 285.79. still have problems. I get choppy playback and then Sony vegas crashes. It doesn’t respond after
  • Scott Francis
    November 22, 2011 at 12:59 pm
    What do you have as an audio device selected? I have a Presonus Firestudio and if that is the devise, Vegas locks up, if I used Microsoft Mapper, it resolves that issue….may not work, but you can try it…
    Regards
    Scott Francis
    Mind’s Eye Audio/Video Productions
