Activity Forums Adobe After Effects GPS data graphic overlay from external file
  • GPS data graphic overlay from external file
    Posted by Scott Manley on October 26, 2011 at 1:22 am
    Hello,
    I was wondering if anyone had had experience loading data from an external XML, TXT, or CSV to show a graphic representation of speed, lat/long, etc from a GPS device via the custom scripts panel?
    I was able to export the GPS data from the new contour+ and wanted to make speedometer and elevation overlays for the video.
    In the contour storyteller software there is an option to export GPX cross platform GPS data. I was able to add a .TXT to the end of the GPX file and found out its an XML document.
    Also I can export CSV data from the storyteller software, but I think it truncates the Lat/Long data to 2 decimal points.
    Can anyone please help me?
    Thanks for your time.
    Scott Manley replied 14 years, 7 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    October 26, 2011 at 6:13 am
    This definitely requires a script. Perhaps the COW’s Expression Forum is a better place for your Q. Additionally, https://www.aescripts.com is another place you should visit.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Scott Manley
    October 26, 2011 at 6:17 am
    Hi Roland,
    I will check out that section, thank you.
    I have started a question over at aescripts already with no response, yet.
    -Scott
  • Scott Manley
    October 26, 2011 at 4:17 pm
    Hi Todd,
    Thank you for pointing me in the right direction. I really appreciate it.
    I’ll do some digging and see what the next step will be.
    -Scott
