Activity › Forums › Compression Techniques › GoToMeeting codec question
  • GoToMeeting codec question
    Posted by Matt Sonberg on June 25, 2009 at 10:23 pm
    I’m trying to recompress a file that was created using the gotomeeting codec (already downloaded). Here’s the question. I’d like to get the same kind of quality that they’re getting with a similar file size in Windows Media format.
    The footage is very simply a web meeting, so the content is very power pointish so to speak. The length of the video is 40 min’s and the original file size is just about 40 megs. I need to clip about 9 min’s off of that original file and then render out the new shorter version.
    Using: Windows XP Pro Version 2002 SP3
    Software: Squeeze 4.5 and PPro CS2
    Source Codec: GoTo Meeting’s Codec
    Codec I’d like to Use: I need it to be played back using WM… not sure which codec I need to use
    Destination: Digital Video – mainly used on pc’s
    PPro is showing the original size as 1024:768. Not sure if thats important.
    Any advice?
    Daniel Low replied 17 years, 3 months ago 2 Members · 1 Reply
  • Daniel Low
    June 26, 2009 at 4:22 pm
    Have you tried the Windows Media Screen Codec?
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
