Activity Forums Apple Final Cut Pro Legacy got stuck in online/offline
  • got stuck in online/offline
    Posted by Niti Shah on August 20, 2007 at 10:15 am
    Hi
    I am facing application quitting and low memory problem in the following scenario.
    I have two identical FCP setups, one I am using for offline and second for online. I do my offline cut on one machine (PAL-DV) and take the project though media manager to another one for online (8-bit).
    As I start my online process like mixing color correction. in middle of the work it gives me error of
    Niti Shah replied 19 years ago 4 Members · 4 Replies
  • Peter Wiggins
    August 20, 2007 at 10:46 am
    Have you done a hardware test to see if your memory is ok & installed in the right place?
    Are you using a lot of plugins?
    Peter
  • Rory Brennan
    August 20, 2007 at 2:55 pm
    I’ve had this low memory thing before, but I knew what it was for.
    I have too many projects and sequences open and thus got the error warning.
    closed a lot of unecessary stuff up and problem fixed.
  • David Roth weiss
    August 20, 2007 at 6:29 pm
    [nikei] “I have 3GB of RAM which should not give me out of memory problem for 20 minute length project.”
    What types of hard drive array are you using?
    3gb of RAM is essentially the bare minimum necessary to run FCP on a MacPro. If you have any other processes or apps running your system will begin caching to hard drive, and unless you have a very spiffy hard drive subsystem your machine won’t be able to keep up with all the calls to disk and RAM.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Niti Shah
    August 21, 2007 at 4:36 am
    hi
    Thanks for reply.
    1. I am not using any application along with Final Cut Pro.
    2. I have installed some plug-inns. But same set of plug-inns are in anther system with no issue. But still I will remove it and try.
    3. I have replaced my memory chips
    4. I have 500×3 SATTA internal raid storage.
    Regards
    nikei
