Activity › Forums › Adobe Premiere Pro › Gopro video to premiere cs6
Posted by T-y Birk on June 10, 2014 at 5:33 pmI am having some issues with my gopro video in premiere pro cs6. When I upload the video from the memory card it looks great. However when I edit in premiere the quality is drastically worse. I am creating a sequence from the clip and I thought that premiere should match the settings. I am a novice when it comes to editing and could use some help.
T-y Birk replied 12 years, 2 months ago 3 Members · 3 Replies -
Alaina Ross
June 10, 2014 at 9:17 pmThere are two possible reason as to why your video looks so different in PPro than in what I assume is your media viewer of choice. The first reason is that Premiere Pro will downres your media while you’re viewing your edited sequence so that it doesn’t suck up all your processing power just to preview some changes. The second reason may be that since you aren’t altering your source footage before it comes into PPro, you may be editing in the H264 codec that your GoPro shoots to. This is not an easy codec to work with in most NLEs. Most users transcode or convert their footage before bringing into the NLE so that they can edit with faster responses and better video quality. If you’re using a Mac, I would suggest using my company’s new tool, Edit Ready. Edit Ready allows you to quickly and easily transcode your source footage before beginning your edits, in any of the major editing codecs. You can test this workflow solution by downloading a free trial at https://www.divergentmedia.com/editready
Hope this helps.
Steve Crook jr
June 11, 2014 at 2:38 pmHi! 🙂
I’ll endorse Alaina’s comment that it is likely the Hero’s native H.264 codec that is giving you trouble – when I got my 3 Black everything I read said I had to convert for NLEs.
Besides Alaina’s suggested software, GoPro has a free suite on it’s website that will do the conversion as well.
https://gopro.com/software-app/gopro-studio-edit-software
Also, there is no need for conversion at all if you go to Premiere CC – they have magically fixed the problem that there is no solution for! 😉 (Alas, since I already had CC all that research and experimentation to convert was mis-used – I’ll not say wasted, since I get to help you!)
Good luck!
Steve Crook, Jr.
http://www.stevecrookjr.meI am a simple creative professional that can get my Adobe suite and a few other creative tools to do what I want. Barely. 🙂
T-y Birk
June 12, 2014 at 1:43 pmThanks so much for your help. I installed premiere CC last night and am hoping this will solve the problem.
