Activity Forums Adobe Premiere Pro GoPro Protune Raw Hero 3 Workflow
  • GoPro Protune Raw Hero 3 Workflow
    Posted by Michael Tapp on January 23, 2013 at 8:49 pm
    Hi all,
    I’ve been testing out the Hero 3 and I am stoked that GoPro added on more features for filmmakers.
    I’ll lay out my workflow below, but I am sure there is a better path.
    Shoot in 2.7k, 24p, Protune, Raw White Balance, → Convert in GoPro Cineform → Adjust WB and exposure in Cineform → Export .mov from Cineform → Import .mov into Premiere
    I’ve heard that some people color correct the raw GoPro footage in AE in a 32bit floating point comp. What’s your workflow for protune raw GoPro Footage? Any insight will be much appreciated!
    Ocram Rengaw replied 13 years, 5 months ago 6 Members · 6 Replies
  • Tero Ahlfors
    January 24, 2013 at 10:24 am
    [Michael Tapp] “I’ve heard that some people color correct the raw GoPro footage in AE in a 32bit floating point comp. “
    That’s pretty silly/overkill when your shot footage is 8-bit.
  • Chris Tompkins
    January 24, 2013 at 2:46 pm
    We shoot the same thing sometimes on the same camera, but!
    We bring the footage straight into APP and CC there.
    Saves a step of compression.
    Chris
  • Bart Johnson
    March 11, 2013 at 2:01 pm
    Chris,
    Are you able to directly import the mp4 2.7k Protune footage into Premiere and edit without choppy playback? I would like to avoid compressing with CineForm Studio altogether, but I haven’t been able to get smooth playback in APP CS6. I’ve read reports of many others having this issue as well. Something about that Protune codec apparently.
  • Chris Tompkins
    March 11, 2013 at 3:34 pm
    I too prefer NOT to add a compression step by stopping by CineForm.
    But, NO, I do not get smooth play back in APP, I have to render first.
    Chris
  • Steven Sall
    March 15, 2013 at 4:16 pm
    Regardless of smooth playback.
    I am still unable to import 120fps footage directly into Adobe Premiere without the footage playing back at 60fps. Every clip I import is in slow motion from the onset.
    Is there a way to have it play back in real time without adjusting the speed duration of every clip I import?
  • Ocram Rengaw
    March 27, 2013 at 2:12 am
    Try using the interpret footage feature and tell PP it’s 120fps. works like a charm.
