Activity › Forums › Apple Final Cut Pro Legacy › GoPro file unknown
  • GoPro file unknown
    Posted by Paolo Drusi on July 23, 2017 at 10:52 pm
    Hello,
    File Error: Unknown File
    This message appears when I try to add a GoPro file into FinalCutPro 7. I’ve tried exporting the file in different formats and codecs but I always get the same error message. Any thoughts why this is happening?
    I’m aware I’ve posted very few details here, but before doing that, is there anything obvious I’m missing?
    Thanks a lot
    p
    Shane Ross replied 9 years, 2 months ago 2 Members · 3 Replies
  • Shane Ross
    July 24, 2017 at 6:42 pm
    Sorry Dave, GoPro cameras have been around a lot longer than you think. They were in heavy use when FCP 7 was still being made and updated.
    No, the problem is that FCP 7 doesn’t always like the H.264 codec…which is what the GoPro uses. You need to convert that to ProRes and then import into FCP 7. Use Compressor for this, or media encoder or EditReady…any number of converters. But convert to ProRes 422 or ProRes LT before you bring it into FCP 7
    Shane
    Little Frog Post
  • Paolo Drusi
    July 25, 2017 at 11:59 am
    Thank you Shane,
    that’s exactly what I’ve done but the puzzling thing is that if I do a test clip from a 10″ segment of the GoPro footage and export it as ProRes it can be imported and used in FC no problem. When I then export the whole file with exactly the same settings, I get the error message. This is why I’m stuck.
    Any clues why this might happening?
    Thank
    P
  • Shane Ross
    July 25, 2017 at 6:17 pm
    What are you using to convert? What’s the frame rate of the GoPro footage? Frame size? I know GoPro can shoot odd frame rates and sizes.
    Shane
    Little Frog Post
