Activity Forums Adobe Premiere Pro GoPro 60fps Audio Sync in Premiere Pro
  • GoPro 60fps Audio Sync in Premiere Pro
    Posted by Keith Hopkin on November 23, 2011 at 3:07 pm
    I’m shooting GoPro at 60fps.
    I import to Premiere Pro CS5.
    In library the footage says it is 59.9401. I assume this is the actual frame rate.
    Interpret footage > 29.97 (i’ve tried 30 as well)
    Play back in the source monitor, audio and video is slowed and in sync.
    Drag to timeline, audio and video is in sync.
    As soon as I make an edit with the razor, anything after that point is now out of sync.
    I just found somewhat of a hack solution though. If I nest the clip and then make an edit to the nested clip the audio is in sync.
    Any ideas??
    Keith
    vimeo.com/keith
    Keith Hopkin replied 14 years, 9 months ago 2 Members · 2 Replies
  • Chris Tompkins
    November 23, 2011 at 7:13 pm
    Did you try taking the original clip and dropping it on the new sequence icon and let APP match the settings?
    Chris Tompkins
    Video Atlanta LLC
  • Keith Hopkin
    November 23, 2011 at 9:28 pm
    Thanks for the tip. that doesn’t seem to work though. It doesn’t seem to be directly related to the timeline’s settings since the audio is in sync. But as soon as an edit is made it’s like Premiere no longer knows how to keep the clips in sync.
