Activity Forums VEGAS Pro GoPro 4k60fps Footage Won’t Load
  • GoPro 4k60fps Footage Won’t Load
    Posted by Daniel Johnson on July 24, 2020 at 9:37 am
    I am using Vegas Pro 13.0, but when I try to import footage from my GoPro Hero 7 Black, filmed at 4k60fps, I’m told
    “Warning: An error occurred while opening one or more files.
    The file is most likely corrupted or of an unknown format.”
    I tried converting my videos with Handbrake, but unfortunately haven’t been able to do so without quality loss (and a lot of processing time). Does anyone know how to resolve this? Has this been resolved with later versions of Sony Vegas?
    Daniel Johnson replied 6 years, 1 month ago 2 Members · 4 Replies
  • Francois Pénzes
    July 24, 2020 at 12:13 pm
    Hi Daniel
    Mediainfo on your file would help us help you.
    https://mediaarea.net/fr/MediaInfo/Download
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Daniel Johnson
    July 24, 2020 at 1:17 pm
    Not sure which will be most relevant, so I’ve included just about everything
    General
    Complete name : E:\Mweni\GoPro Days 1 and 2\GX011902.MP4
    Format : MPEG-4
    Format profile : Base Media / Version 1
    Codec ID : mp41 (mp41)
    File size : 331 MiB
    Duration : 46 s 46 ms
    Overall bit rate : 60.4 Mb/s
    Encoded date : UTC 2020-07-14 11:53:37
    Tagged date : UTC 2020-07-14 11:53:37
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main@L5.1@Main
    Codec ID : hvc1
    Codec ID/Info : High Efficiency Video Coding
    Duration : 46 s 29 ms
    Bit rate : 60.1 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 (60000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.121
    Stream size : 330 MiB (100%)
    Title : GoPro H.265
    Language : English
    Color range : Full
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : hvcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Duration : 46 s 37 ms
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Nominal bit rate : 48.0 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 1.04 MiB (0%)
    Title : GoPro AAC
    Language : English
    Other #1
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 12:05:00:00
    Time code, striped : Yes
    Title : GoPro TCD
    Language : English
    Other #2
    Type : meta
    Bit rate mode : Variable
    Other #3
    Type : meta
    mdhd_Duration : 46029
  • Francois Pénzes
    July 24, 2020 at 1:41 pm
    Hi Daniel
    Your version of Vegas Pro, V13, can’t natively open H265 files. Support for H265 started with V14.
    Quick and short history on the H265. This type of file was originally meant for broadcasting purposes and is also used in Blue-Ray. If at all possible, try to use another file type that will be recognized and won’t make your CPU huff and puff.
    Cheers !
    Radeon RX 5700 XT
  • Daniel Johnson
    July 24, 2020 at 1:56 pm
    Thank you very much! I suppose I’ll have to upgrade then – probably about time. I’m glad to hear that it works with later versions at least, that’s good news.
