Activity Forums Apple Final Cut Pro Legacy GoPro 1080i mp4 Issues
  • GoPro 1080i mp4 Issues
    Posted by Steve Clay on August 20, 2010 at 4:52 pm
    Recently I’ve started working with a couple GoPro HD cameras and I’ve been having some issues with editing in final cut.
    Some clips are jerky in playback no matter what I do.
    First, the manual says that the GoPro Hero shoots 1080p 30fps, although when I bring them into FCP or MPEG Streamclip they are 1080i.
    I’ve tried converting in both FCP and MPEG Streamclip with a variety of settings, and each time it still comes out a bit jerky.
    I’ve mostly been trying variations of Apple ProRes 422 and 422 HQ, or DVCPRO HD.
    Almost all of the shots I am having problems with are shots where someone is either crossing frame, or standing up into frame. Is it possible that this is something with the camera, not the codec? Would shooting at 60fps help?
    Steve
    Jean Le breton replied 15 years, 9 months ago 5 Members · 12 Replies
  • 12 Replies
  • Jason Brown
    August 20, 2010 at 8:31 pm
    surely you aren’t editing in the h264 codec? I use this camera all the time…I transcode to ProRes Proxy, then edit.
    Also, you are saying 1080i…but the gopro doesn’t shoot interlaced…it’s progressive (I believe it’s Psf)
    (check out this video I shot of my kids with the GoPro)
    https://www.youtube.com/watch?v=MFiUu0oZfWQ
  • Steve Clay
    August 20, 2010 at 8:44 pm
    The reason I said 1080i is because when I bring the raw GoPro footage into FCP, the sequence settings automatically change to 1080i. Also it has upper field dominance and I was under the impression that progressive video does not have a field dominance at all.
    I’m not editing with H.264. I’m still trying to figure out proper settings to make the video play smooth in quicktime OR FCP.
  • Rafael Amador
    August 21, 2010 at 12:22 am
    [Dave LaRonde] “Change the field order (incorrectly referred to as “field dominance”) of your FCP edit timeline to None. “
    And also check all the stuff as NONE in the Browser.
    Rafael
    http://www.nagavideo.com
  • Jason Brown
    August 21, 2010 at 2:21 am
    [Steve Clay] “when I bring the raw GoPro footage into FCP, the sequence settings automatically change to 1080i.” First off, 1080i is the frame size, and it’s a bit antiquated language…check the setting below that that says “field dominance”. That should say “none”
    And, this may just be my workflow…but FCP isn’t a program that is going to read this kind of information from a compressed video file very accurately.
    If you transcode the footage through compressor, you can do a “pass-through” of all these settings. (frame size, frame rate, field dominance) if you just set compressor to transcode to ProRes (I use proxy because the bit rate is close to the source bitrate) and do a “same as source” on all the aforementioned parameters…that will give you an accurate “editable” file to take into FCP and have the sequence match.
    -Jason
  • David Roche
    August 21, 2010 at 5:54 pm
    Check out this from GoPro’s website – Importing & Exporting GoPro Video in Final Cut Pro 7.0:
    https://www.goprocamera.com/tips/fcp.php
  • Jean Le breton
    November 19, 2010 at 8:09 pm
    hi
    I just read you post and I’m interresing with your setting about compressor because I have the same problem with the gopro footage in finalcut I get 1080i
    can you tell us the setting you use in compressor
    thank in advance
  • Jason Brown
    November 19, 2010 at 8:46 pm
    It’s very basic, In compressor:
    Encoder:
    File Format – Quicktime Movie
    Video settings – Enabled- Apple ProRes 422 (LT)
    Frame Rate: 29.97
    Audio Settings – Enabled – PCM Stereo 48khz – Little Endian
    Frame Controls:
    Off
    Geometry:
    100% of source
    Hope that helps…
    -Jason
  • Jean Le breton
    November 19, 2010 at 9:35 pm
    thank for your quickly reply
    I test your setting
    but I have another question when I import my footage to compressor I get in the A/V attributs windows native field : upper field first I don’t know why if the footage of gopro is progressive I must get this information
    have you the same thing
    sorry for my english and thank you for your help
  • Jason Brown
    November 20, 2010 at 1:27 am
    [Jean Le Breton] “but I have another question when I import my footage to compressor I get in the A/V attributs windows native field : upper field first I don’t know why if the footage of gopro is progressive I must get this information “
    I hadn’t ever taken a look at this, but I just did and some 1920 footage I shot awhile ago came in the AV attributes as “bottom field first” — which doesn’t even make sense, because HD is UFF.
    Either way, the gopro footage ISN’T interlaced…so it’s a moot point. If you set field dominance on footage that doesn’t have fields…it doesn’t do anything.
    -jason
  • Rafael Amador
    November 20, 2010 at 10:39 am
    [Jean Le Breton]
    This is a matter of how the applications identify the footage.
    But this is an issue for you to address because YOU know that the footage is Progressive.
    I would recomend you to use MPGStreamclip.
    Make a plain transcoding keeping all the original setting but the codec (Prores).
    In MPGStreamclip, treat the stuff as Progressive.
    Conform your p30 to p29,97 with CinemaTools.
    [Jason Brown]
    Frame Rate: 29.97
    Frame Controls:
    Off
    I don’t see much convenient changing the Time-base while having the “Frame Control: OFF”.
    rafael
