Activity › Forums › Apple Final Cut Pro › Google Earth KMZ files into FCP
Posted by Craig Ryder on April 30, 2013 at 9:48 amI’d like to import Google Earth KMZ movie files into FCPX. Is there a (best) way/conversion to do this?
Thank You
CraigMark Freeman replied 10 years, 8 months ago 3 Members · 2 Replies -
Matt Larson
May 1, 2013 at 9:15 pmIt’s been a while since I’ve used Google Earth, but isn’t there a way to export Quicktime movies from the application? Save them out as ProRes files and they should import into FCPX just like anything else
Mark Freeman
January 11, 2016 at 7:49 pmI was searching for a solution to this problem
Old solution:
- Found that Quicktime screen capture was being recommend in the past.
Newest solution:
- Since Google Earth Pro is now free, you able about to create Movie from a “Tour” (Add / Tour).
Steps:
- Make you tour: Go to Add / Tour and create your Google Map tour
- Make your movie: Go to Tools / Movie Maker. Lots of formats to choose from in thet setup.
- Import to FCPX
Keywords: movie google maps earth pro import final cut fcpx tour movie maker
Mark Freeman
Vancouver, BC, Canada
