Activity › Forums › Apple Final Cut Pro Legacy › Good work routines in FCP
  • Matt Lyon
    May 11, 2011 at 1:54 pm
    Thanks Toni. After posting, I realized a slightly different way of doing the autoselect thing: You can “option-click” the autoselect box on a track, and make it instantly solo’ed.
    [Toni Martin Dobrzanski] “14.) In Premiere there is a really neat feature where you can drag a clip from the browser onto an existing clip in the timeline while holding the ALT key. Premiere then substitutes the clip with the new one but keeps all the information from the clip that was already in the timeline (so all motion, effects, in/out is kept).”
    I believe you have to use the copy-paste attributes feature as the only way of achieving this.
    [Toni Martin Dobrzanski] “15.) Is it possible in FCP to reveal a clip from the timeline in the browser? When I right-click on a clip in the timeline I can choose ‘Reveal in Finder'”
    I like to map “command-shift-f” to the “reveal in finder” command. Saves a lot of clicking over the years. I picked up that tip from another thread on The Cow!
    Toni, have you tried playing around in the “keyboard layout” window? (option-h). You can learn a lot about various obscure/poorly documented commands in the software.
    Matt Lyon
    Editor
    Toronto
  • Toni Martin dobrzanski
    May 11, 2011 at 2:08 pm
    Thanks you two!! you rule 🙂
    i’m up and running in speed again 🙂
    I’ll check out the keyboard layout Matt… good point.
    Cheers!!
  • Misha Aranyshev
    May 11, 2011 at 5:02 pm
    If you really want to get fast in FCP hire a guy who would slap you every time you touch the mouse.
    [Toni Martin Dobrzanski] “13.) When dragging a clip from the browser to the timeline it’s possible to choose to ‘insert’ or ‘overwrite’ by holding the mouse in the upper or lower part of the track. Is it possible to choose ‘insert’ when moving clips around in the timeline from one place to another (in Premiere done by holding CTRL while moving clips)?”
    Never drag anything. Copy then paste. On timeline Command-X will cut and leave the gap, Shift-X will cut and close it. Command-V will overwrite, Shift-V will insert.
    [Toni Martin Dobrzanski] “14.) In Premiere there is a really neat feature where you can drag a clip from the browser onto an existing clip in the timeline while holding the ALT key. Premiere then substitutes the clip with the new one but keeps all the information from the clip that was already in the timeline (so all motion, effects, in/out is kept). In that way you can quickly substitute the picture material while still keeping all the editing information of a clip. Is something similar possible in FCP? Is this what you called “replace” (F11) Michael?”
    Replace will replace both content and attributes. Copy the source clip in the browser, select the target clip on the timeline, Option-V, while in the dialog box check “Content”, uncheck everything else.
    It is very crude way of doing it actually. When I want to change one clip for another on the timeline, I usually want the exact frame of source clip to fall on exact time in the cut. That’s what Replace is for. Park on a frame in the master, park on a frame in the source, hit F11. The source will get into the edit with head and tail trimmed. If I need to keep attributes I Command-C the target clip before replace and Option-V right after.
    By the way, Replace works without a target clip as long as there are some boundaries — a gap or IN-OUT marks on the time line.
    May 11, 2011 at 8:14 pm
    Michael… you’re good! I like your style!! 🙂
Page 2 of 2
