Activity Forums Audio Good shotgun/hyper cardiod mic for video
  • Good shotgun/hyper cardiod mic for video
    Posted by Daniel Schultz on February 2, 2011 at 1:25 am
    I’ve been using the Rode Video Mic on my HMC150 as an onboard shotgun, as well as putting it on a mic stand for interviews (out of frame). It’s served me fairly well, but I’d like to upgrade to an xlr and a bit higher quality with a separate shock mount (the video mic is 1/4 inch mini and has a built in shock mount which you have to use and is not very good).
    Would anyone care to recommend a mic in the 200-300 range?
    I’m hoping to use it for the following:
    • On a mic stand, just out of frame, above 1 or 2 subjects’ head for video interviews
    • On board the camera for run and gun (last resort, but sometimes necessary)
    First, would people recommend a hybercardiod over a shotgun (supercardiod)?
    I heard that the Oktava MK 012 is a good hypercardiod for the money.
    Thanks in advance for your advice.
    Dan S.
    Eric Toline replied 15 years, 7 months ago 2 Members · 1 Reply
  • Eric Toline
    February 2, 2011 at 3:35 am
    The Oktava 012 has notorious LF handling issues. Not a mic for run & gun although if it’s mounted in a good shock mount on a good boom pole on a solid stand it could work fairly well. You’ll need a mixer with a LF or high pass filter to eliminate any thumps & bumps it will pick up. If you find a used AKG Blueline set with the hyper capsule & the shotgun capsule you’ll be better served. Check out ebay for AKG Blueline.
    Eric
