Good Shotgun Replacement to use on the Sony PMW-EX1
Posted by Wes Browning on April 18, 2009 at 3:34 pmI’m currently using a Azden SGM-1X on my Sony PMW-EX1. I’ve been having some major problems with clipping, and haven’t been able to figure what the cause is. You can see this issue, and sample audio here: https://forums.creativecow.net/thread/142/862028
I’ve been thinking about an upgrade anyway, which leads me to my question about a good shotgun mic…
I’d like to get the Sennheiser ME64 or ME66, and wanted to know if anyone had any problems like described above with it (ie. clipping in loud situations). With the SGM-1X, it doesn’t seem to matter how much i adjust the input levels, the problem is always there.
If you’ve used the Sennheiser ME64 or ME66, which one do you like better, and do you have to get the K6 powering module if your camera has phantom power (like the Sony PMW-EX1).
Wes Browning replied 17 years, 5 months ago 3 Members · 8 Replies -
Wes Browning
April 18, 2009 at 9:32 pmI don’t run it through a mixer, I just go straight to camera. If I run it through a mixer, it’s no big deal getting the levels where they need to be. When running it through the camera input, I have the option of adjusting it –8 dBu to –65 dBu. It never really seems to matter how low I adjust it, it always comes out distorted if the sound is too loud (except when using the mixer). I’d prefer to use the camera without mixer.
Is there a major difference between the Rode NTG-3, Sennheiser ME64 or ME66?
Ty Ford
April 18, 2009 at 9:35 pm[Adam Browning] “I’m currently using a Azden SGM-1X on my Sony PMW-EX1. I’ve been having some major problems with clipping, and haven’t been able to figure what the cause is. You can see this issue, and sample audio here: https://forums.creativecow.net/thread/142/862028
>> You’re not using a mixer? Could be the camera input just can’t be adjusted properly.
Try a Rode NTG-3.If you’ve used the Sennheiser ME64 or ME66, which one do you like better, and do you have to get the K6 powering module if your camera has phantom power (like the Sony PMW-EX1).”
>>yes.
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitarSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Ty Ford
April 18, 2009 at 9:50 pm[Adam Browning] “I don’t run it through a mixer, I just go straight to camera. If I run it through a mixer, it’s no big deal getting the levels where they need to be. When running it through the camera input, I have the option of adjusting it –8 dBu to –65 dBu. It never really seems to matter how low I adjust it, it always comes out distorted if the sound is too loud (except when using the mixer). I’d prefer to use the camera without mixer.
>>And apparently, that’s not working too well for you, so you’ll have to do something different.
Is there a major difference between the Rode NTG-3, Sennheiser ME64 or ME66?”
Yes.
Ty Ford
Watch Ty play guitar -
David C jones
April 20, 2009 at 7:06 pmHi Adam-
In terms of using a [shotgun] mic on the EX1, I would set the trim at -41dB which is the factory setting anyway. But since you’re not using a mixer, you’ll need to put the mic/line-in switch to auto. Unfortunately, this is a AGC which is the only way to employ some sort of limiting in order to prevent distortion from happening.
Regards,
Dave J -
Wes Browning
April 21, 2009 at 4:53 pmI had a gig yesterday and I set the gain down to -23 dB, and didn’t have any problems when in an extremely loud environment. I think I may go with Ty’s suggestion and try the Rode NTG-3. How does this mic compare to my Azden SGM-1X?
I found the specs on both mics, and besides the frequency response and S/N ratio I didn’t see a huge difference. Is that what makes the Rode NTG-3 so great? Here are the specs…
RODE NTG-3
Power P48 (48V) phantom supply
Acoustic Principle Line Gradient
Directional Pattern Super Cardioid
Frequency range 40 Hz – 20 kHz
Output impedance 25Ω
Signal noise ratio 81 dB SPL (A – weighted per IEC651)
Equivalent noise 13 dB SPL (A – weighted per IEC651)
Maximum SPL 130dB SPL (@ 1kHz, 1% THD into 1KΩ load)
Maximum output voltage 8.2dBu (@ 1kHz, 1% THD into 1KΩ load)
Sensitivity -30 dB re 1 Volt/Pascal (31.6 mV @ 94 dB SPL) +/- 2 dB @ 1kHz
Weight 163gm
Dimensions 255mmH x 19mmW x 19mmDAZDEN SGM-1X
FREQUENCY RESPONSE 80-18,000Hz
SENSITIVITY SUPER CARDIOID -33dB re 1V/Pa
IMPEDANCE 1.5k Ohms @ 1KHz
MAX. SPL INPUT LEVEL 110dB
SIGNAL TO NOISE RATIO 65dB
DYNAMIC RANGE 80dB
BATTERY TYPE AAA (1.5V) – USE ALKALINE BATTERY
BATTERY CURRENT 0.2 mA
BATTERY LIFE 1000 HOURS w/ALKALINE BATTERY
WEIGHT w/o BATTERY 4.76oz (135grams)
DIMENSIONS 11.8″ (300mm) length
0.83″ (21mm) diameter
OUTPUT TYPE 3-Pin XLR type -
Ty Ford
April 21, 2009 at 5:02 pmAdam,
More to the point, what makes the Azden not so great. Once you get out of the Azden league, provided you have good enough headphones to hear the difference. (Sony MDR7506 or Audio Technica ATH-M50)
Specs seldom tell ANY story worth reading.
Regards,
Ty Ford
David C jones
April 21, 2009 at 8:26 pmI agree with Ty (as I always do); it’s not just about specs but quality [of parts] and workmanship. That being said, the specs difference between the mics do tell a story…esp. the S/N, Fq. response, AND SPL.
