Activity Forums Maxon Cinema 4D good plugin for moving object axis?
  • Adam Trachtenberg
    September 10, 2011 at 2:26 pm
    Have you tried the built-in Axis Center function?
    If you are planning on upgrading, R13 has some nice new features for axis translation/alignment.
  • Ryan Paterson
    September 10, 2011 at 5:24 pm
    I have used the built in functions, yes. Looking for something that works with parametric objects as well. Will R13 have anything like that?
  • Brian Jones
    September 10, 2011 at 7:01 pm
    other than just dropping the parametric in a Null you can use the Correction deformer to move all the points of a parametric wherever you want in relation to the axis.
