Activity › Forums › Adobe Audition › Good PCI soundcard?
Good PCI soundcard?
Posted by Mickavid on April 30, 2005 at 1:18 amHi Willie,
Is the creative pci soundcard a good deal? much of a difference between the 50 and 75 dollar versions? Will it solve my latency problems?
Tx,
MickWillie Toth replied 21 years, 4 months ago 4 Members · 9 Replies -
Willie Toth
April 30, 2005 at 1:29 amI used a 16 bit soundblaster card for several years without any difficulty … What type of problem are you having?
Mickavid
April 30, 2005 at 9:41 pmHey Willie,
Just the typical latency issues with the factory cards. I am using a laptop for my audio programs and want to get into basic multi-track recording, so i need a card that will give me real time monitoring. Other than that – no problems.
Mick
Willie Toth
April 30, 2005 at 11:13 pmMick,
I would go with an outboard system if you are using a laptop … Presonus makes a nice unit that connects via USB … WILLIE
Mickavid
May 1, 2005 at 6:04 pmyea – sorry, i meant pc slot. but i see that the usb models are out there too. i’ll look into that solution. tx
mick
Barend Onneweer
May 7, 2005 at 12:03 pmAs an alternative you could look into M-Audio solutions. M-Audio have always created very reliable equipment, and have a bunch of mobile options out there.
https://www.m-audio.com/index.php?do=products.list&ID=mobileinterfaces
Personally I prefer a Firewire interface over USB. I’ve seen too many latency issues with USB…
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Chad Treanor
May 27, 2005 at 4:04 pmWillie-
i posted here a while back stating i wanted to be able to record a good voice over and was having trouble. I concluded that i would just wait to find a mic pre-amp or just get one of the firewire solutions that seem to have pre-amps in them. I was looking at the Digidesign M-box for the past two years basically and i just dont know if i want to pay that much for it. I already used protools a while back when i was in school but now that im out i have Audition and i want to be able to record a good VO.
so i looked at the last post Barend Onneweer and his link to the M-audio stuff. I’ve seen this one firewire break out tool that has an XLR and quarter inch input that seems like it would be able to handle a simple sm58 w/ an xlr. I think thats all i would need to record decent VOs.
Im posting this to see what you think about this one piece of hardware as far as quality of recorded audio and functionality w/ audition.
https://www.m-audio.com/products/en_us/FireWireSolo-main.html
any help is appreciated.
chadwikgood thread to read as well
Willie Toth
May 27, 2005 at 4:26 pmI think for the price this is OK … M-audio is middle of the road when it comes to equipment but for what you are wanting to do you are probably good to go … I prefer a 57 over a 58, I know they say they are the same with the exception of the case config, but to my ears I hear a difference … The only thing more I might add is a rule of thumb that I use when purchasing equipment … I make it a practice to purchase equipment that is more than I need … The unit you are looking at has only one XLR input, to my way of thinking I would say that this is a liability … If you are absolutely sure that you will never need anything more, then go for it, if not maybe look into a different unit … Hope this helps ………. WILLIE
Chad Treanor
May 27, 2005 at 5:33 pmthanks for the good direction Willie…Im almost positive that i will need this piece of hardware for VO recording. I plan on doing multi-camera shoots later on and I plan on getting a mackie mixer for that so if it ever came down to it I could just use that when in need. Then again that may be a few years down the road. This m-audio hardware will be a good start though. overall im starting in post production and later on moving into production work.
thanks
chadwik -
Willie Toth
May 27, 2005 at 7:24 pmChad,
There are better ways to go than Mackie … Mackie is known for their live boards and their sound is geared towards grung … You might consider going with a Tascom 8 track, this is what I use for doing shoots where I only need 2 recordables in’s … It’s nice because you have a USB out to make it an easy transfer to your computer for edit … When you get ready contact me and we will get you travelin down a productive road … My E-mail address is loganonestudio@aol.com …… WILLIE
