Activity › Forums › Sony Cameras › Good news for SDHC
Good news for SDHC
Posted by Ron Pestes on September 30, 2009 at 9:28 pmI just got the Hoodman SDHC adapter with a Transcend 32 gig card. So far they work perfectly. In other posts I have read that some people get an error when they try to record short clips one right after the other without letting the red light go green above the card slot. I tried this and never had a problem. The recording just didn’t start until the card was ready but there were no errors. The only thing I don’t like is it is easy to dismount the card from the adapter when you push it to get it out of the camera or Express card slot on the computer.
Darrell Boeck replied 16 years, 11 months ago 8 Members · 17 Replies -
Craig Seeman
October 1, 2009 at 1:37 amGreen strip under the word Transcend or Red background behind the word Transcend on the card?
Ron Pestes
October 1, 2009 at 2:17 amGood question. I have heard that red is possibley bad. However, mine is red and in the advertisement that came with the card it shows a picture of all the cards they make and they are ALL red regardless of type and size. My test was to run the card until full and then do a series of short shots. No problems yet but have not tested frame rate yet for under and over cranking.
Craig Seeman
October 1, 2009 at 2:31 am -
Brent Critchfield
October 1, 2009 at 3:45 amNope, I have red 16GB cards, and am having lots of problems with them. Even getting media restore errors shooting 1fps timelapse footage.
Craig Seeman
October 1, 2009 at 3:57 amBrent maybe this is important.
Maybe Transcend
16GB Green – Good
16GB Red – Risky32GB Red only (no Green exists) – Good
If we here from others maybe we can definitively determine which Transcend cards are good or troublesome.
Lucian Evans
October 1, 2009 at 1:39 pmFinding it all quite stressful with the Transcend cards. I’m using 16gb class 6 and am getting constant media errors. Back in the office testing everything and its solid with SxS but isnt liking the Transcend cards at all. I am very keen to save a few pounds (pal land) but cant cope with the uncertainty while shooting.
I’m not sure if the colours make any difference at all but mine are 16gb red.
cheers
Lucian -
Craig Seeman
October 1, 2009 at 1:47 pmLucian, if you read the above, color MAY make a difference at least with 16GB Transcend.
So far the pattern is
16GB Green – good
16GB Red – risky
32GB Red (only comes in red apparently) – goodWhen people report issues with Transcend
PLEASE include
16GB or 32GB and Green or Red.If enough people respond we can discern the pattern which is much better than making a blanket statement about Transcend cards.
Daniel Startek
October 1, 2009 at 2:15 pm16 GB Transcend RED with the Kensington Card. Have been using it continually for the past month with no read/write errors.
Craig Seeman
October 1, 2009 at 3:08 pmThanks for that Daniel.
While it’s hard to say anything definitive this is what I deduce so far:
Green is always good (are there any bad reports on this yet).
Red may or may not be good (some work, some don’t).It almost reminds me of the way Resistors are measured. I believe it was Gold and Silver bands which defined the range.
Green may be to tighter tolerances/specs. That would me some Red would certainly work because a tolerance is a range, not an absolute. The loser tolerance means that some Red will work and others will fail.
All speculative at this point and certainly not even enough anecdotal data yet but it’s certainly something worth exploring.
