Activity Forums Apple Final Cut Pro Legacy Good Idea or Already Possible?
  • Good Idea or Already Possible?
    Posted by George Snow on February 16, 2012 at 7:39 pm
    I’m trying to save space. I have a PowerPc and I’m working with DSLR footage. So it’s a pain, but it does work.
    Is the following already possible?
    I have a file which is 2 gigs/2 minutes long. I only use ten seconds of that file.
    Is there anyway I can create a new file of just that ten seconds?
    Then I can store away the original on an Ext HD.
    This will free up a ton of space.
    My idea which would be time consuming is, create a QT movie for each cut and then reassemble the scene.
    If I did this using the EXPORT QT MOVIE (not QT conversion) would I lose a lot of quality?
    George Snow replied 14 years, 7 months ago 4 Members · 5 Replies
  • Steve Eisen
    February 16, 2012 at 8:07 pm
    Set in set out export self contained movie. No quality loss if you keep current settings.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • George Snow
    February 16, 2012 at 8:15 pm
    Thank You!
  • Tony Brittan
    February 16, 2012 at 9:02 pm
    Or even one it in QuickTime and select in/out points to delete unwanted sections and delete them. Save remaining file as new file name and viola!
    Posted from iPad, please excuse typos!
  • Alex Elkins
    February 17, 2012 at 2:42 pm
    Hi George,
    FCP’s Media Manager would be the best tool for the job here. My only question would be to ask why you actually need to reduce the file size – a 2GB file is tiny!! Having a smaller file is not going to make your playback any better, if that’s what your computer is struggling with. You need faster harddrives and a file format that FCP and PowerPCs are comfortable with (such as DVCProHD).
    Alex Elkins
    Twitter: @postbluetv
    http://www.postblue.tv
    Post Blue showreel
    Latest work: Greyhounds in Motion at 500fps
    My Vimeo Pro page
  • George Snow
    February 17, 2012 at 3:54 pm
    At the moment I’m unemployed and broke. I’m also in the middle of shooting a movie. So, space is at a premium. I have a firewire drive I’m using to store the footage I’m using and a USB drive I’m storing everything on.
    There’s no problems playing the footage on the firewire drive, but it’s old and only holds 250gigs. But, if I try to play the footage from the USB drive (new 1 tb) it stops every two seconds with dropped frames.
    So,I need the space, and it’s working like a charm. I’ve freed up over 100 gigs so far. And I still have about another 100 once I complete the sound from the original files.
    It makes sense from a poor man’s perspective.
